Threads: 13
Is there a way to set the value of an knx object without triggering a script or writing on the bus?
Nicky
Do you mean you want to change internal object value in LM? Can you give some detail on why do you need this?
You can use event.sender field to check what caused the script to execute. It will be either bus or a two-character string, different for scripts, user action etc.
Threads: 13
Ok that is indeed an option, i will try that
Threads: 13
How can I determine which script triggered the update?
The two character string does not seem to be unique per script?
No, but you can set your own 2-char id by setting grp.sender field before calling any other grp functions.
