setting value of object without triggering script or writing on bus
Is there a way to set the value of an knx object without triggering a script or writing on the bus?
Nicky
Do you mean you want to change internal object value in LM? Can you give some detail on why do you need this?
(16.01.2018, 07:25)admin Wrote: Do you mean you want to change internal object value in LM? Can you give some detail on why do you need this?
Indeed i have created a Gateway for Yamaha devices where the commands to the Yamaha device get triggered through  Objects tagged with Yamaha which Works perfectly,
But if I sync the device state through a deamon, which is needed when the user uses his remote for instance then I end up in a loop by triggering the same command again to the Yamaha
If I do not do the status update on that object but another specific status object I cannot use check write anymore.
You can use event.sender field to check what caused the script to execute. It will be either bus or a two-character string, different for scripts, user action etc.
Ok that is indeed an option, i will try that
How can I determine which script triggered the update?
The two character string does not seem to be unique per script?
No, but you can set your own 2-char id by setting grp.sender field before calling any other grp functions.
