replaced smartphone and tablet/pc default colors
I have homelynk (2.1.1) with default css.
So default colors is green on my smartphone and table/pc visu. How to change this color easy to F00000 for example?
http://192.168.0.10/scada/vis/theme.css....sion=2.1.1 holds all the used CSS for a selected theme, if you pick the correct rules from it and set them to custom css you can do it quite fast..
(26.01.2018, 15:09)Erwin van der Zwart Wrote: Hi,
can you please give me a quick example and where to place the custom css?
Vis Graphics ->Edit Custom CSS
Sample:
.navbar-inner, .nav .active .a, .nav .active .a:hover, .nav .a.active{     background-image: linear-gradient(#534767, #143111); } a, .a{     color: #08c; } .nav .a:hover {     box-shadow: inset 0 0 0 1px #08c; }
many thanks..
