Blink function
HI,
what is the way to create a blinking icon ?
CSS ?
Do you have an example for me ?
I'm looking for a logic that blink an icon when the knx address is true.
Something as the code below....is it right ?
/* Blink for Webkit and others (Chrome, Safari, Firefox, IE, ...) */ @-webkit-keyframes blinker {  from {opacity: 1.0;}  to {opacity: 0.0;} } .blink{     text-decoration: blink;     -webkit-animation-name: blinker;     -webkit-animation-duration: 0.6s;     -webkit-animation-iteration-count:infinite;     -webkit-animation-timing-function:ease-in-out;     -webkit-animation-direction: alternate; }
Regards,
Alberto
KNX Advanced Partner + Tutor
(06.02.2018, 16:13)toujour Wrote: HI,
CSS ?
Regards,
Alberto
Why din't you make gif icon which will be blinking and just add it for ON state.
Because it is not scalable...it is the last solution !! Wink
HI,
With SVG icon and css Shy
Jean-Marc
Hello all,
I have tested the CCS code and it works fine when I add 'blink' to the element's additional class. The problem is that in that case the icons is blinking always. Can I make this to static icon when object value is 0 and blink when value is 1?
Edit: When setting the element 'read only' this doesn't work. Can this be fixed?
Any help is appreciated.  Smile
