Threads: 28
There is no option out of the box for this today.
Work around:
1. Create your widget as a small plan. If you have it as widget now just export it and import under plans.
2. Now you can duplicate it as many time you want.
3. Use frame to display your plan(widget) on the plan.
Threads: 28
True, in this case you have to hide menu and create it manually on the plan via links. Use Layout for that to simplify it.
To hide menu go to vis configuration->Usermode sidebar->hide
Threads: 86
Hi , I want to show my widget in a frame. my widget graphic id is 8. when i my make widget url /scada-vis/#8 , i can't see the widget. What is the proper link to show my widget in frame ?
Threads: 43
You can't show widgets like this, only plans. What are you trying to achieve?
Threads: 86
Ok i did it with plan. Thank you.
