Error not sending file via ftp service!
Hi everybody !
I have this code to save the backup file to the NAS service (using the ftp protocol). On the Lm3 (I use version 20170424), I opened the ftp service (login successful)
On nas synology, i open ftp service (login successful, full privileges for fpt_user directory).
When running the script on LM3 it again error as shown below:
"string: 553 <fpt_user> LM_nha_mau_HN-2018.02.26_12-28.tar.gz: Permission denied."
Have you met this case yet? And where is the error?
Please help me !
Thank so much!
Are you sure it should be fpt_user, but not ftp_user?
yes, I'm sure !
Sad
Have you checked with another FTP client if you can upload files to this account? Also check that you can upload to root folder, or only to a specific folder. You might have to adjust path in FTP upload script on LM.
Thank admin !
I use script:
--Take a backup and ftp to NAS
-- name of backup file
src = 'LM_nha_mau_HN-' .. os.date('%Y.%m.%d_%H-%M') .. '.tar.gz'
-- where to put backup file on LM
dst = '/home/ftp/' .. src
-- where to put the backup on NAS
target = '<fpt_user>' .. src
-- prepare files for backup
os.execute('sh /lib/genohm-scada/web/general/backup.sh')
-- create archive
os.execute('cd /lib/genohm-scada/storage && tar -c -z -f ' .. dst .. ' ./')
-- load the ftp support
local ftp = require("socket.ftp")
local ltn12 = require("ltn12")
-- ftp to NAS
f, e = socket.ftp.put{
host = "100.100.100.99",
user = "fpt_user",
password = "gammajsc",
type = "i",
argument = target,
source = ltn12.source.file(io.open(dst, "rb"))
if (e) then
log (e)
log (f)
alert("Could not ftp: ", e, "\n")
log("ftp_backup")
-- cleanup
os.execute('cd /home/ftp && rm -rf backup_*')
os.execute('cd /lib/genohm-scada/storage && rm -rf user userlib.luas blockly.luas initscript.lua helpers.js genohm-scada.config filter*')
Am I something wrong? Please help me
Could it be that you configurered sftp?
If so try to use the adapted script below, but you also need a new FTP package which you can find here
please install updated package:
https://dl.openrb.com/lm-17/pkg/luasocke...21_mxs.ipk
require('socket.ftp')
-- CONFIG
FTP_TARGET_FOLDER =  ''
FTP_TARGET_IP =  ''
FTP_TARGET_LOGIN = ''
FTP_TARGET_PW = ''
-- FUNCTIONS
-- backup the config and transfer it to the nas
function backup()
 log("System Backup: started")
    src = 'backup-' .. os.date('%Y.%m.%d_%H-%M') .. '.tar.gz'
    target = FTP_TARGET_FOLDER .. src
    -- create archive
    -- ftp to NAS
 log("System Backup: transfering backup to NAS, host:" .. FTP_TARGET_IP .. ", target:" .. target)
 res, err = socket.ftp.put({
     host = FTP_TARGET_IP,
     user = FTP_TARGET_LOGIN,
     password = FTP_TARGET_PW,
     secure = true,
     datasecure = true,
     type = "i",
     argument = target,
     source = ltn12.source.file(io.open(dst, "rb")) })
    if (err) then
   logMsg = "System Backup: failed with error:"
   if (error) then
     logMsg = logMsg .. err
     logMsg = logMsg .. "nil"
   if (res) then
     logMsg = logMsg .. ", result:" .. res
     logMsg = logMsg ..  ", result:nil"
   log(logMsg)
   alert("System Backup: failed, could not ftp to NAS, host:" .. FTP_TARGET_IP .. ", target:" .. target)
   alert(logMsg)
    -- cleanup
 log("System Backup: completed")
Thank so much !
I'm will try !
This line is probably incorrect:
Try this:
target = 'fpt_user/' .. src
Or this:
target = src
