BACnet client
I'm trying to use LM as bacnet client using this example:
http://openrb.com/logicmachine-as-bacnet-client/
I'm having trouble with one specific equipment that doesn't respond to the scan. Is there any way to configure the device manually?
The equipment in case is a Fire detection panel which works mainly with Life Safety Points.
Thank you in advance,
Neves
Life Safety Point objects are not supported yet. Do you need to control any other properties apart from mode?
