Creation of custom package
How can I create custom package for LM?
I need custom websocket connections with TV and other stuff and I want to use this connection inside LUA resident or event scripts.
The main idea is I create a package which works as HTTP server on some local port and it has and ability to create websocket clients inside.
e.g.
event script
ws = require('lua.websocket')
tvConnection, err = ws.connect('ws://my.tv.ip:3000') -- (blocking with t/o) send to local HTTP server
                                                     --  a command to connect if no connection
tvConnection.send('raw data') -- send text or array of bytes to 'ws://my.tv.ip:3000'
resident script 0 sec
data = tvConnection.receive() -- receive array of data came from 'ws://my.tv.ip:3000'
Could you please create kind of this stuff? Or give me instruction how to build own package, I know C/C++, Golang, JS, Lua
Thank you in advance!
There's a pure Lua websocket client library. It should work on LM with some minimal changes.
As for custom packages we do not provide build tools but we can provide some custom packages by request.
Attached is websocket client library ported from https://github.com/lipp/lua-websockets/
Main changes:
1. Support for basic auth in URL
2. Receive timeout does not close the websocket connection
3. Server support is removed
Add it as a user library named websocket
Minimal example (resident script):
if not ws then
  ws = require('user.websocket')
  url = 'ws://admin:admin@192.168.1.12/apps/localbus.lp'
  -- mode is either sync or copas, second parameter sets timeout in seconds
  client = ws.client('sync', 10)
  client:connect(url)
log(client:receive())
.lua   websocket.lua (Size: 13.64 KB / Downloads: 30)
Thank you. This is great. Is there an recommend way for connecting to multiple websocket servers with this client?
Thanks,
Roger
I am trying to use the copas part because being a resident script i need to run a udp server to accept an event script client.
On connecting with the copas parameter I get the following in the error log.
Library copas:0: attempt to yield across C-call boundary
stack traceback:
[C]: in function 'yield'
Library copas: in function 'connect'
User library websocket:500: in function 'sock_connect'
User library websocket:438: in function 'connect'
 ws = require("user.websocket")
 url = 'ws://demos.kaazing.com/echo'
 client = ws.client('copas', 10)
 client:connect(url)
I am using the following UDP server code for taking requests from the LM objects.  effectively the websockets client needs to running asynchronously  so it doesn't block the udp server running.  In the past I have used copas to do this.
 local server = usocket.udp()
 server:setsockname("127.0.0.1",53450)
 function handler(skts)
   skts = copas.wrap(skts)
   alert("UDP connection handler")
   while true do
     local s, err
     alert("UDP receiving..")
     s, erro = skts:receive(2048)
     if not s then
       alert("Receive error: %s", erro)
       break
     alert("Received data, bytes: %s",s)
      -- send to the websocket
     client:send(s)
 copas.addserver(server, handler, 1)
You need to wrap websocket client in copas mode with function passed to copas.addthread
Is there an example from this?  Because that's what I am trying. thx Roger
if not ready then
 socket = require("user.websocket")
 usocket = require("socket")
 copas = require("copas")
 ready=true
 apps = {}
 --helper functions to round and increment values
 function increment(n)
   n = n + 1
   return n
 function parse(data)
   alert('parsing: %s', data)
   local response = string.split(data,' = ')
 function sendCommand(command)
   skt:send(command)
   sleep(1)
 function init()
 function fromKNX(command)
   local telegram = string.split(command,',')
   log(command)
   while true do
     local s, err
     if not s then
       break
     fromKNX(s)
if not skt then
url= 'ws://demos.kaazing.com/echo'
 skt,err = socket.client('copas',5)
 skt:connect(url,80)
 skt:send('hello')
 -- when theres no error connect ok, initialize
 if(not err) then
   -- add receive thread
   copas.addthread(function()
       while true do
         local resp,err = copas.receive(skt)
         -- if theres no connection start a new connection
         if not resp then
           alert("[tcp-client] Receive error: %s", err)
           copas.removeserver(skt)
           skt = nil
           break
         local fd,prtd = pcall(parse,resp)
         if(fd==false)then
           alert("Error with parsemsg %s ",prtd)
     end)
   if skt then
     alert('[tcp-client] connection ok')
     init()
     -- error while connecting,
     if warningfailed then alert('[tcp-client] connection failed (conn): %s', err) end
     return
   alert('[tcp-client] error connecting %s',err)
   return
copas.loop()
connect part must be inside copas thread
Ok adding the connect in the thread works. Thank you. The timeout parameter doesn't seem to have any effect. The connection always lasts about 10 seconds disconnects and reconnects. Is there no way to keep it permanently connected?
Another thing I need to account for is that the webservice is not always running. It's live when the device is powered on. So what I see is that the script would be constantly trying to reconnect. I guess the only way to handle this is by disabling the resident script when the device is powered off. Unless you have any other idea?
thanks
Roger
Disconnect might happen from the server side. To keep connection alive you probably need to request data periodically or send ping frames.
As for reconnect, enable/disable is one approach, another one is just to keep script running and check if connect is ok or not. When device is offline then connect function will return once timeout is reached.
(26.03.2018, 08:42)rocfusion Wrote: Hi,
thanks
Roger
Hi Roger,
Did you have any success getting your LG TV to work with this? Also did you manage to support connecting to multiple clients?
I'm trying to do the same (I have 2 LG WebOS TVs I'd like to control).. but I'm a complete newbie to Lua.
Nick
