18.03.2018, 10:32
(This post was last modified: 18.03.2018, 10:42 by phongvucba.)
Hello everybody! I have a problem, it should ask people, and does anyone have done yet?
). the problem is that I want to insert many lm5 in the same network or other network (make hotel rooms). in the figure his example I have 6 lm5, 4 lm5 in strip other network modem original and 2 lm5 in the same range network with modem. each lm5 to control for a room, a system EIB separate each other. so I have to configure each lm5 how? because I saw the control address 1/1/2 on lm3 (1), the address 1/1/2 on lm3 (2) or lm3 (4) will change the value in.: ((. has anyone install many lm5 for hotel yet?
Thank so much!
). the problem is that I want to insert many lm5 in the same network or other network (make hotel rooms). in the figure his example I have 6 lm5, 4 lm5 in strip other network modem original and 2 lm5 in the same range network with modem. each lm5 to control for a room, a system EIB separate each other. so I have to configure each lm5 how? because I saw the control address 1/1/2 on lm3 (1), the address 1/1/2 on lm3 (2) or lm3 (4) will change the value in.: ((. has anyone install many lm5 for hotel yet?Thank so much!
