Modbus write multiple register
Hi to all,
I have to write a single register to a device that only supports Function 16
If I use this it's not working
--COMANDO ON/OFF  mb:writeregisters(33822,32)
but if I add another register it'll works
--COMANDO ON/OFF  mb:writeregisters(33822,32,0)
I suspect that the function automatically switches between function 6 and 16 based on the number of registers it has to write.
I know it makes little sense to use MultipleRegister to write a single register but that's the way the device works and I can't change it so I just want to know if is it possibile to "force" function 16 passing only one register.
Thank you
You can force function #16 for single write like this:
mb:writemultipleregisters(33822,32)
Perfect, works like a charm!
Thank you
