Threads: 1
A KNX object can be connected to multiple -same type Group addresses. One of them has sending property. In many cases this is essential. How can we achieve the same goal with logic machine? A feedback group address is not always possible. One solution is to write some short of LUA for each object but this will make the project complicated and unreadable. A direct input of listening only addresses for an object would be very helpful.
Threads: 3
In what case do you need this?
Script only. Use tags to make it simpler.
Threads: 86
I think this post can be helpful for you and it will be the most efficient way.
https://forum.logicmachine.net/showthrea...45#pid2945
Done is better than perfect
Threads: 1
16.04.2018, 13:55
(This post was last modified: 16.04.2018, 14:00 by ncgnick.)
Thank you all
All that was the obvious reaction from my side.
It would be easier if there was a straight forward procedure. This would keep the project more readable
Just think of a project with 5000 GAs and a central function switching off everything. I wouldn't even think of such a solution and I wouldn't dare to let all the feedbacks pass through all the line couplers and routers just for the visualization
Developers, please consider this functionality in future firmware releases
