Gardena smart
Anyone already linked a Gardena Smart gateway?
Here my first code to read a Sensor and write the moisturelevel and batterylevel.
function getData()
  https = require 'ssl.https'
  require('json')
  socket.http.TIMEOUT = 5
 local cUsername = 'email@abc.com'
 local cPassword = 'password'
  -- get session info
  local cBody = '{"sessions":{"email":"' .. cUsername .. '","password":"' .. cPassword ..'"}}'
  local cReq = {}
  local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/sessions'
  result1 = https.request({
      url = cUrl,
      method = 'POST',
      headers = {
        ['content-length'] = #cBody,
        ['content-type'] = 'application/json'
      source = ltn12.source.string(cBody),
      sink = ltn12.sink.table(cReq)
  if result1 then
    --log(cReq)
    cReq = table.concat(cReq)
    cReq = json.pdecode(cReq)
    if cReq then
      --log(cReq)
      token = cReq.sessions.token
      user_id = cReq.sessions.user_id
  -- get location info
  local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/locations/?user_id=' .. user_id
  result2 = https.request({
      url = cUrl,
      method = 'GET',
      headers = {
        ['X-Session'] = token
  if result2 then
    --log(cReq)
    if cReq then
      --log(cReq)
      local loc_name = cReq.locations[1].name
      loc_id = cReq.locations[1].id
  -- get device info
  local cUrl = 'https://sg-api.dss.husqvarnagroup.net/sg-1/devices?locationId=' .. loc_id
  result3 = https.request({
      url = cUrl,
      method = 'GET',
      headers = {
  if result3 then
    --log(cReq)
    if cReq then
      --log(cReq)
      local dName = cReq.devices[1].name
      for k,v in pairs(cReq.devices) do
        --log(v)
        --log("Found the following GARDENA "..v.category)
        --log("Name: "..v.name)
        --log("Identifier: "..v.id)
        -- gateway
        if (v.category == "gateway") then
        -- sensor
        elseif (v.category == "sensor") then
          for a, b in pairs(v.abilities) do
            for c, d in pairs(b.properties) do
              --log(d.name)
              --log(d.value)
              if (d.name == 'last_time_online') then
                --check = tostring(d.value)
              elseif (d.name == 'humidity') then
                grp.write('1/1/1', tonumber(d.value))
              elseif (d.name == 'level') then
                grp.write('1/1/2', tonumber(d.value))
        -- onbekend apparaat
          log('onbekend gardena apparaat: '..v.category)
You need to check the result of https.request call instead of cReq variable. Since it's defined as a table first if cReq then... will evaluate as true.
(25.04.2018, 06:45)admin Wrote: You need to check the result of https.request call instead of cReq variable. Since it's defined as a table first if cReq then... will evaluate as true.
thanks for the comment.
gjniewenhuijse,
I'm interested in this project as i'm installing a Smart Sileno Life 750 robotic mower this week and planning to extend this with Smart Water Control + Sensor and Smart Pressure Pump and maybe some Smart Power Plugs to control lights.
I'm a novice on scripting and things and would like to learn and understand more of this. It's not always clear where things go and steps to follow to get things working.
Can you, or anyone, explain me what to do and where to do it? I have a HL, wich is similar to the LM.
Thx in advance
I found this page with API for all Gardena Smart products:
https://developer.husqvarnagroup.cloud/a...I#/general
Kind regards,
Novice DIY with a HL and KNX basics trying to ...
"This API has moved to the official developer portal. Please follow the instructions at https://developer.husqvarnagroup.cloud"
