Threads: 1
I am trying to use spacelynk as a bacnet client. I have found a package for LM but I can't find a way to install it on SpaceLynk. Please help me if you can.
Thank you
Threads: 29
SE do not support this package so you should talk to those support if they let you install it.
There will be an app for bacnet client soon.
Threads: 7
10.05.2018, 07:59
(This post was last modified: 10.05.2018, 08:02 by Erwin van der Zwart.)
For this App we first need our new FW (just like for new presence simulation app), when new FW is out we launch the BACnet client in the store.
I have seen the BACnet client app already and you can use it completely without script, so that is very cool (: Just scan BACnet (ip) world and bind the found objects to KNX objects by a few menu options.
In the backend is also scripting available with all options of the BACnet client package when needed.
Threads: 29
BACnet server and BACnet client can run at the same time only if they use different BACnet port.
The app will be the same what current client only you will not have to use script for object mapping.
