[Profile] Modbus Read Multiple Coils
HiĀ  Cool !
I have to read aprox. 80 coil registers from each of several equips but I want to read the registers with just 1 request like I do with INT values.
I have tried with the following example (test with 4 variables) but it doesn't work !
(For reading holding registers this way works fine)
Any ideas?
{"name":"Test1","bus_datatype":"1","type":"coil","datatype":"bool","address":0,"writable":0,"read_count":4,"read_offset":0,"read_swap":"n" }, {"name":"Test2","bus_datatype":"1","type":"coil","datatype":"bool","address":0,"writable":0,"read_count":4,"read_offset":1,"read_swap":"n" }, {"name":"Test3","bus_datatype":"1","type":"coil","datatype":"bool","address":0,"writable":0,"read_count":4,"read_offset":2,"read_swap":"n" }, {"name":"Test4","bus_datatype":"1","type":"coil","datatype":"bool","address":0,"writable":0,"read_count":4,"read_offset":3,"read_swap":"n" } (...)
Please change address and try again. And what is the current result? What you have in Logs, Errors, Alerts?
And here you have some post about limits:
https://forum.logicmachine.net/showthread.php?tid=1278
Done is better than perfect
Multiple read for coils is not supported yet, we'll look into adding it to next firmware.
(15.05.2018, 20:21)buuuudzik Wrote: Please change address and try again. And what is the current result? What you have in Logs, Errors, Alerts?
Which address ?
What happens with the 4 variables I have posted is that they have the same value (from the modbus address 0).
(16.05.2018, 06:15)admin Wrote: Multiple read for coils is not supported yet, we'll look into adding it to next firmware.
Okay, thank you.
It will be a very very important feature to have.
Is there any news about this feature ?
I'm testing a SL with FW 2.4.0 and is still not supported :\
Thank you
There is already much newer FW for SL, try using 2.5.1
This was never implemented, we are doing it right now.
