Threads: 87
Hello
Just wondering about importing the knx file to Logic Machine 5.
I have imported the file and made my visualization.
But the when i modify the text of group adresses and try to import the file again, the modified group adresses gets discarded. So my old text is still in logic machine. It works but i wont to update my text for new group adresses.
What is the right way to do this. ?
Thanks for any answer in advance.
Threads: 8
15.05.2018, 20:48
(This post was last modified: 15.05.2018, 20:48 by Erwin van der Zwart.)
That is correct, objects already existing in the controller are skipped, so you must rename it manual (double click on the object line) or delete it and re-import the object from ESF.
Threads: 30
Yes it will re-link. It is mapped to the address not to the name.
When graphical element has no object linked to it will have red mark around it.
Threads: 57
If i delete all objects in logic machine, and reimport the new ETS file with all the name changes i have done. Is there anything at all that will have to be reconfigured og linked, or will absolutely everything start working again like before the deletion?
Kai-Roger
Sent fra min SM-G930F via Tapatalk
Kai-Roger
Threads: 30
It depend. Each group has its parameters and if you delete group the parameters are also deleted. When you import new objects then they may not have correct DPT like 1byte unsigned instead of scale. All depend of what changes you did to the objects after importing original.
In Short all object parameters will have to be re-done so it is better to delete only the ones which were changed.
Threads: 52
Please, make a flag on the import function for it !!
KNX Advanced Partner + Tutor
