Threads: 100
Hi ,
I need to increase size all the Circular Sliders in my project. If you share css code, i will be pleased.
Thanks,
Threads: 8
23.05.2018, 20:55
(This post was last modified: 23.05.2018, 20:56 by Erwin van der Zwart .)
You can do that by using the mass edit function on the object tab. Filter your objects and edit the vis parameter 'Size' of the circular slider control types.
Threads: 12
be careful. mass edit will change all sliders params (line color, buttons)
Threads: 100
Changing size didn't worked.
I attached 2 screenshots. One of them has %300 size . Other has %200 size. As you can see size are same in both screenshots
Threads: 30
As description says this works only in show control mode.
.popover.control-circularslider {
transform: scale(2)!important;
This should do, it will change all sliders.
Threads: 100
Hi there,
Can you send same code for custom value select , direct input and slider alternatives ?
Thanks,
.popover.control-vselect - custom value select
.popover.control-slider - slider
.popover.control-spinner - numeric input
