Webserver Refuses to connect
I am facing a connection problem with a HL (LSS100100). The device is replying on ping requests but every time I am trying to connect on the webserver (http) i am getting the message ERR_CONNECTION_REFUSED. Have tried Firefox, Chrome and MS Edge also Private Browsing.
Used to work just fine and now cannot access it anymore. I have done a hard reset and the problem is still there even connected directly on it using a FTP Patch cable.
FW version is 2.0.1 if i remember correctly. The HW came with the FW V1.2 (RN-2015-W09-483).
Is there any way I can access it and restore a factory default .img?
The easiest is via fallowing this http://openrb.com/reflash-logicmachine3-...-software/  use  this image https://dl.openrb.com/recovery.img.gz
I would also use brand new card as most likely something went wrong there.
(29.05.2018, 14:07)Daniel. Wrote: Hi
Hello Daniel.,
Thank you for the reply. Indeed your suggestion worked perfectly. Replaced the Micro SDHC card also.
Best regards,
