Threads: 33
Is it possible to add scheduler right inside Mosaic? I imagine this option as mini corner button which calls new window with time scheduler and "back" button.
Another option is a trick and easier to implement. Adding somewhere button to "export mosaic objects to scheduler" is worse option but might be the case.
Threads: 21
The only way today I see is via inline frame widget. You can past it there /scada-vis/schedulers but it require much bigger size something like 4,4 at last I think.
I will add to the roadmap a widget which will open in popup.
Threads: 24
Are there any news on this? Is there an easy way to do this in Mosaic 3.0? Can it be accessed remote?
Have a project where I need this function to control a ventilation system.
BR Even Sundgot.
Threads: 21
(19.12.2018, 18:03)Evens Wrote: Hi,
BR Even Sundgot.
We are planing to make dedicated widget for schedule but it is not planed in 3.0
Threads: 24
I see, so we will probably not see this widget in 2019? or?
Threads: 21
2019 is possible.
