DALI DT8 lamps and Dynamic white scenario
can we build with LM Dynamic white scenario solution??? Any ideas??
(Who don't know - now popular theme in lighting - DT8 DALI lamps type (can change color/color temperature using DALI protocol). Dynamic white scenario - idea is that  in the morning office light has white cold light, later became warmer (as sun color temperature)... Closer to the end of working day light's color temperature again will be more cold...)  Now many companies produce lamps with DALI and possibility to change color temerature from 3000K to 6500K.. Are LM support DT8 lamps type?  I know that Schneider has KNX/DALI GW
with DT8 support..
What do you think??
Alex
I think you should use our gateway (:
(06.07.2018, 12:33)Erwin van der Zwart Wrote: Hi,
Erwin, good answer Wink
May be you can send me more details/info about it? How from KNX/scripts change DT8 color temperatures regarding Dynamic white scenario? Somewhere I saw script or description, could not find it..
Alex
