Modbus KNX datatypes doubt
Hello, I have a question about data types in Modbus and KNX, many times in Modbus commands appear options to turn on or off something but it make this not using a boolean but an integer, my question is whether it is possible to define the Modbus part as integer but in KNX as a boolean to simplify the config. Thank you very much
You can map registers to boolean objects on LM, but only if ON equals 1 and OFF equals 0 in ModBus register.
