ETS - ESF import with "parent level names" included
Hello.
If i use "http://openrb.com/knxproj/" to convert from KNXPROJ filetype, to JSON filetype, i get the option to: "Include parent level names in object name". Very practical indeed.
Is this possible to do this altso when importing ESF filetypes directly in "import ESF file" under the "utilities" ribbon? Include the "parent level names" that is?
Kai-Roger
(09.08.2018, 15:37)Kai-Roger Wrote: Hello.
Kai-Roger
you can open .ESF file with notepad and you will see that there is no parent names in this file.
there are no data types in esf too.
Kai-Roger
Thanks. Then i will continue using the json import
Sent fra min SM-G930F via Tapatalk
Kai-Roger
