Threads: 17
I've lost the password file for several LM-s that I installed last summer.
Is there any way to recover the password? Maybe login over serial console?
I have the backup files (*.tar.gz) for them intact.
Threads: 30
Sorry only HW factory reset. If you have backup you can restore project.
Threads: 30
No admin pass in backup. Old fw did contain user passwords as plain text but in latest even this is encrypted.
Threads: 47
If you can connect SD card to Linux then it's possible to set password via config file edit.
Threads: 47
You have to edit /etc/config/httpd
Set password in plain text, it will get hashed during next boot
Threads: 47
Sorry to hear that. Since LoadBalancer is a PC you can connect a monitor and a keyboard, go to BIOS, enable boot from USB and use a Linux live USB to access the on-board eMMC. The main partition should be either /dev/mmcblk0p1 or /dev/mmcblk0p2. Make sure to use a newer live USB distribution as older one won't have eMMC support. As for old LM2, check if SSH is enabled. If it is enabled then can you provide remote access so I can reset the password?
