Thanks admin, that worked fine!
However, the script pushes a hell load of data to influx that is not really necessary.
I could use the "range" tip from above, but using "tags" would be easier and more flexible for future changes.
I tried my best, but I don't think I understand event.getvalue to be honest.
This particular GA have 2 tags, one of them is "influxdb"
BTW, any suggestion on the timestamp manipulation?
function knx_callback(event)
local id = event.dstraw
local tagname = event.getvalue(tag)
if tagname == "influxdb" then
local addr = event.dst
local value, dt = get_value(addr, event.datahex)
if value ~= nil then
send_metric('rawdata', dt.name, addr, value)
local http = require('socket.http')
http.TIMEOUT = 5
local url = 'http://192.168.1.200:8086/api/v2/write?bucket=XXX&org=XXX'
local token = 'XXXXX'
local influxtable = 'rawdata'
local tagobjs = grp.tag('influxdb')
local function escape(value)
return tostring(value):gsub('[\\ ,=]', '\\%1')
local objects = {}
for _, obj in ipairs(tagobjs) do
objects[ obj.id ] = {
name = escape(obj.name),
datatype = obj.datatype,
local function send(name, addr, value)
local body
if type(value) == 'boolean' then
body = string.format('%s,name=%s,addr=%s state=%s', influxtable, name, addr, value)
body = string.format('%s,name=%s,addr=%s value=%s', influxtable, name, addr, escape(value))
Above script is working perfectly however is there a way I can use this as a scheduled script?
I see it's now kept resident and sends data according what is generated by the objects and that can be alot making one object hijacking the stream.
I tried changing the busclient and while loop part but without any success, it only sends one objects data and then stops.
Is there any info on the localbus and how to use it?
You don't need localbus for this as the current object value is already stored in the database.
http.TIMEOUT = 5
local body
I have noted that influxDB somehow doesn't like the BOOL values sent to it. When trying to show the values I get the error "unsupported input type for mean aggregate: boolean"
If I set aggregate function to last in influxDB, it just give me an infinite line. Doesn't show the actual state of True/false.
Should the BOOL values also be "escape(value)" as the strings?
It looks like you've already written a boolean value into "string" field so it won't accept string data into this field anymore. Either choose a different field name and modify the script accordingly. Or delete the bucket and create it again.
12.01.2024, 12:08 (This post was last modified: 12.01.2024, 12:11 by DGrandes.)
Hi!
I have a question about Grafana representacion of influxdb data. I know that is grafana question but anyone says nothing, this forum is not active... Mayby somebody made.
I send data from LM to influxdb when they change, no in scheduled script.
If I put time filter I can't see the first value (the value before the change). And if there are no changes in the data in the filter, it says "No data". Is there a way to represent the last value in the database if there are no changes?
