Threads: 2
17.08.2018, 20:22
(This post was last modified: 17.08.2018, 20:23 by IMSELKNX.)
Hello!!
How I can integrate multiple LogicMachine devices located in different cities, to access to it since single graphical interface?
Thks!!
There's no ready made solution for this but there are many possible approaches. Do you need two-way control or only value monitoring? Will it be a custom interface or another "central" LM?
Threads: 2
21.08.2018, 13:19
(This post was last modified: 21.08.2018, 13:19 by IMSELKNX.)
I need value monitoring only. I have the possibility to use a BMS or a central LM.
Threads: 31
There is one out of the box option but not sure if it will suit you. If you use Mosaic as your visu then on cloud you can jump between your LMs via Cloud Mosaic. It is not quite single graphical interface but you will access them from one place.
