FB editor value decimals
Hi.
No big deal, but when the temperature values in FB editor reaches 21.4 C, the decimal number count gets very big. Is this normal? See the picture. Next to group 5/2/9 in top left corner.
Check what value you have in Object tab.
Hi.
When i write any number with a decimal of 0.4, i get 0.400000000000002
This altso happens when i write 0.9
You probably use a 4 byte float object, does the object in configurator object tab shows the same value as in the editor? If yes try to change the object to 2 byte float.
(25.08.2018, 06:49)Erwin van der Zwart Wrote: Hi,
Hi. It's 2 byte float value thats selected.
Can you send me your backup?
Sent Backup PM
Thanks, we know what it is and will fix next time we will work on FB.
