KNX IP backbone
Can I use 2 LM5 as IP backbone/KNX routers?
For example they would be 1.0.0 an 2.0.0 and connected in the same IP network, below main lines would be TP (1.1.0, 1.2.0 and 2.1.0, 2.2.0 Line-couplers).
And in this case could both LM5 serve a huge amount of KNX group addresses and 1.0.0 LM be as main board for visualization?
Yes but you have to be careful not to overload KNX bus. Much better is to keep every line on KNX IP only. Too big traffic can cause some issues in TP Uart getting too hot.
(27.08.2018, 08:06)Daniel. Wrote: Hi
Thank you.
