Threads: 69
Hello
Could we make the degree variable from the name Like: Rotate-xx
where xx is the degree we wants
Best Regards,
Threads: 40
See this if you want to rotate an icon based on linked object value:
https://forum.logicmachine.net/showthread.php?tid=1831
Threads: 69
Hello Admin
I want to set the rotation angle from the custom name.
I want to use it for one bit Linear Lighting object
Could we do some thing like that based on the custom name value
Best Regards,
Threads: 40
Custom name cannot be accessed from Custom JS at the moment. This can be done via Additional classes. This code will look for all elements where class list contains
rotate-XYZ (where XYZ is an angle value in degrees). No custom CSS is needed for this solution, the rotation is applied by the code itself..
$(function(){
$('[class*=rotate-]').each(function(index, el) {
var match = el.className.match(/rotate\-(\d+)/);
el.style.transform = 'rotate(' + match[1] + 'deg)';
Threads: 69
11.04.2022, 07:47
(This post was last modified: 11.04.2022, 07:48 by khalil .)
(11.04.2022, 05:34) admin Wrote: Custom name cannot be accessed from Custom JS at the moment. This can be done via Additional classes. This code will look for all elements where class list contains rotate-XYZ (where XYZ is an angle value in degrees). No custom CSS is needed for this solution, the rotation is applied by the code itself..
$(function(){
Thanks Admin
Great
Could we use custom name in the tooltip or not yet?
Best Regards,
Threads: 40
Custom name will be accessible from JavaScript side in the next firmware.
Threads: 69
(11.04.2022, 09:23) admin Wrote: Custom name will be accessible from JavaScript side in the next firmware.
Great news
Best Regards,
Threads: 69
Hello admin.
Could we use custom name in tooltip, if you could share an example.
Best Regards,
Threads: 21
Threads: 40
Use the example above but change the content property to this:
content: attr(data-object-name);
Threads: 69
(21.02.2023, 12:22) admin Wrote: Use the example above but change the content property to this:
Hello Dears,
It didn't work, does it work with CSS and no need to use JS?
I am mean object properity: Custom name.
Best Regards,
Threads: 40
If custom name is empty then object name will be used. This works for me:
.usermode [data-object-name]:before {
display: none;
position: absolute;
top: -30px;
height: 20px;
line-height: 20px;
left: 0;
background-color: #eee;
padding: 2px 6px;
border-radius: 3px;
.usermode [data-object-name]:hover:before {
display: block;
Threads: 69
What should I use in the additional classes ( tooltip tooltip-1 ) its not used in this CSS code.
Best Regards,
Threads: 21
No need for any additional class for this example. It works only on visualisatin not editor.
Threads: 69
(21.02.2023, 15:28) Daniel Wrote: No need for any additional class for this example. It works only on visualisatin not editor.
I tried on SL and Wiser for KNX, but it didnt work.
does it work there?
Best Regards,
Threads: 21
In did this is not implemented in SE firmware yet, wait for next fw.
Or add this to custom JS
$(function(){
$('.item-control').each(function(_, el) {
var name = $(el).data('object-name');
if (name) {
el.setAttribute('data-object-name', name);
Threads: 69
(22.02.2023, 08:42) Daniel Wrote: In did this is not implemented in SE firmware yet, wait for next fw.
$(function(){
if (name) {
Thanks Daniel,
Best Regards,
Threads: 19
19.03.2024, 12:23
(This post was last modified: 19.03.2024, 12:25 by manos@dynamitec .)
(09.04.2022, 08:15) khalil Wrote: Hello
Hello admin,
Can we just implement this function for 0-360° and assign name in additional classes?
something like a for i=0 to 360 do......
.rotate-i {
transform: rotate(-ideg) !important;
If then we add additional classes: rotate-1 or 2 or 3 the icon rotates to the correct angle.
Threads: 40
