lost scripts and changes in the visualization
    hi
recently i lost previously saved changes in several scripts, in the user library as well as changes in several pages in the visualization over the past few weeks. it is as if someone would restore old versions, while i am working on the scripts. moreover, if i restore the most recent backup they are not the most recent ones ! i can change something, make a backup and restore and the changes are lost ! it started after i had to hard reset the LM about 5 weeks ago (log). for the rest, it works normally. any idea ? i copied some of the scripts into textfiles to restore them manually... any ideas ?
thanks, christian
LM5 20170106
[attachment=1047]hi
thanks, christian
LM5 20170106
Looks like microSD card in your LM became read-only. You need to replace it with a new one an run recovery procedure. See more info here: http://openrb.com/reflash-logicmachine3-...-software/
