03.12.2018, 13:15 (This post was last modified: 03.12.2018, 13:17 by Daniel..)
(03.12.2018, 12:51)fruitmans Wrote:
(03.12.2018, 12:49)Daniel. Wrote: Current version is quite stable already, more people will help in testing faster it will go out.
Ok than i will make the switch from version 2 to 3 this week ;-) Is there a way to port the current configuration i use for version 2?
You can install both now. We did it in a way that 3.0 does not affect your current project (For testing purpose only). Just export json backup from 2.0 and import to 3.0. Testing backward compatibility is very important so any help is good.
(05.12.2018, 13:21)rogerabit Wrote: Hello.
I can create in IOS and Android phones a direct access to mosaic through cloud?
Or only i can access through LM app?
This is cool. Since it's only "Mosaic" that is available on the "Cloud Service", i have tought about how to access the "Visualization" in another way (except from "port forwarding" and "VPN").
I have used the "Inline frame" widget i the 3.0 version, and just put the local IP adress of the "Visualization" inside. The size of the widget can be adjustet for larger view.
My question is this: Can the widget containing the "Visualization" be used even when the Mosaic 3.0 is available in the "Cloud Service"?
09.12.2018, 22:37 (This post was last modified: 09.12.2018, 22:38 by Kai-Roger.)
Hi. I see from an earlier thread that Daniel answered yes about adding 0,5°C adjusting possibilities to widget builder in 3.0. Is this still to be implemented before release of final Mosaic version 3.0?
(09.12.2018, 22:37)Kai-Roger Wrote: Hi. I see from an earlier thread that Daniel answered yes about adding 0,5°C adjusting possibilities to widget builder in 3.0. Is this still to be implemented before release of final Mosaic version 3.0?
(10.12.2018, 09:12)Kai-Roger Wrote: Hi Daniel. Maybe i misunderstand. In the picture i have a value changer with + and -. I can't adjust it by 0,5. Can i do it somewhere else?
10.12.2018, 09:28 (This post was last modified: 10.12.2018, 09:34 by Kai-Roger.)
Sorry Daniel. Did not se that (:
By the way. Is it possible to access local IP adresses in the "Inline frame", when accessing Mosaic over cloud service?
10.12.2018, 10:20 (This post was last modified: 10.12.2018, 10:40 by buuuudzik.)
How it goes with Mosaic 3.0? It works more and more cool
How can I reach the parent element of script in 'Plain HTML element'? I want create such element without generating some new unique class inside this plain HTML. I want use current widget id or some reference to this "Plain HTML element".
Another thing I've found that error (on fullscreen, in view mode):
It's possible in Video Player widget insert a rtsp video link? If i insert a http video link I can't insert usr and pwd in link (http://user:pwd@ip/port). Thanks.
(10.12.2018, 10:20)buuuudzik Wrote: How it goes with Mosaic 3.0? It works more and more cool
This bug appears on Chrome, not on Firefox.
Did you try latest version? I think it was fixed.
Yes, I am using 20181214.
I was able to recreate it in previous version but not anymore, can you explain how to recreate?
I have a simple dimmer which on Chrome v71.0.3578.98 64-bit (up-to-date). It appears also in Editor, in fullscreen and smaller windows. I see this now also on Firefox. I have very simple project, only for testing from time to time what is the current Mosaic status
