Modbus RTU over TCP
Hi All,
is there any way to get luamodbus working with device using RTU over TCP?
Luca
Which LM version are you using? This has not been tested but it's possible to install and run socat which can create a virtual serial port and proxy data to/from TCP.
(26.10.2018, 07:29)admin Wrote: Which LM version are you using? This has not been tested but it's possible to install and run socat which can create a virtual serial port and proxy data to/from TCP.
Hi Edgars, i'm using LM 2 reactor with latest stable fw. I've thought to socat too .
How can i install and launch it?
Luca
Here's socat package for older LMs: https://dl.openrb.com/pkg/socat_1.7.3.2-1_mxs.ipk
Create a resident script with sleep time of at least 1 second, change TCP settings (192.168.1.100:502) as needed. Then use /dev/ttyVIRT0 as ModBus serial port. Resident script is needed to restart socat in case connection is dropped.
os.execute('socat pty,link=/dev/ttyVIRT0,raw tcp:192.168.1.100:502')
