Hi, does anyone know how to enable swipe for touch visualisations? For user mode it seems to work, if only slow.
Swipe in touch mode Visu
03.07.2015, 12:55
Swipe should work for both normal and touch visualization. Just make sure that you've making swipe gesture on a empty space, not on top of any controls or any other elements. New firmware will have an option to disable swipe if needed.
On which device is it working slowly for you? It should be as fast as any other mouse/touch action like tap/click.
06.07.2015, 12:22
(03.07.2015, 12:55)admin Wrote: On which device is it working slowly for you? It should be as fast as any other mouse/touch action like tap/click. Had not found this feature... now I have. It works well if you have a lot of white space to swipe on... but our start screen fills the full phone hight. That way the WifeAcceptanceFactor falls to the floor. Speed seems to be related to the animations.
08.07.2015, 06:13
Animation is quite resource hungry so use with care, some devices might be too slow for it. I'll see if/how swipe can be improved, thanks for feedback
« Next Oldest | Next Newest »
