Sauna RS485 connection with LM
I want to send command for sauna control over RS485
Comand list
How need to look my command in LM?
require('serial')
port = serial.open('/dev/RS485-1', { baudrate = 57600, parity = 'none', duplex = 'half', databits = 8, stopbits = 1 })
port:flush()
log = port:write (info)
port:close()
port:write('set sauna on\r')
port:write('set sauna val 70\r')
This is correct that I done in resident  for reading:
require('serial')
port:flush()
grp.write('32/2/2', port:write(('get sauna val\r'), 'uint16'))
port:close()
If you want to query status periodically then things get more complicated. You need to have a single resident script which will handle both reading and writing because you cannot have multiple scripts accessing serial port at the same time.
You also need to parse the response because the reply will contain some additional characters.
This should log raw response of temperature value.
function readack()
  local line = {}
  while true do
    local char, err = port:read(1, 5)
    if char == nil then
      return nil, err
    elseif char == ';' then
      break
      line[ #line + 1 ] = char
  return table.concat(line)
port:write('get sauna val\r')
res, err = readack()
log(res, err)
Ok connection is working maybe you know why I get not correct value?
Evrithing is good its working code:
require('serial')
port:flush()
function readack()
 local line = {}
 while true do
   if char == nil then
     return nil, err
     break
port:write('get sauna\r')
log(res, err)
port:close()
