Setpoin shifting and visualization
Hello i touch visu i need one object where i can change setpoint shift (nuber between -8 and +8) and in the middle there will be actual setpoint temperature in degrees C. But i cannot change diferent value type than value FB. Is there any option how to do that?
Use a 2 byte signed integer object and set the vis params to -8 to 8 and stepsize to 0.5.
