Threads: 106
Hi When we are using 2017.09 Firmware with LM5Lp , our bacnet scripts was working very well. Here you can find an example below. After upgrade to 2018.08 , these scripts are not working anymore.
Need help,
Regards,
value = event.getvalue()
require('bacnet')
bacnet.write(9000, 'binary output', 1793, value)
Have you installed BACnet client package? All additional packages must be reinstalled after FW upgrade.
Threads: 106
11.12.2018, 10:54
(This post was last modified: 11.12.2018, 10:56 by savaskorkmaz.)
No , i didn't but when i open package list , i saw a package named
bacnet 2018.03.01
is this bacnet client or something else ? If this is not bacnet lient can you share latest bacnet client please ?
Also there is error like
User script:2: module 'bacnet' not found:
no field package.preload['bacnet']
no file './bacnet'
no file 'Library bacnet'
no file 'Library bacnet.so'
stack traceback:
[C]: in function 'require'
User script:2: in main chunk
