File not found on LM4 (usr/lib/lua/encdec.so)
Hello I have a LM4 that died at customer site last october.
I Finally have it on my desk.
Trying to access it wia WEB-browser, i get the following message:
Lua error error loading module 'encdec' from file '/usr/lib/lua/encdec.so': File not found
I tryed different links, like /apps, /Scada-vis, etc. but none report anything other than the LUA-error.
Any idea what this is?
And what to do?
Found some small sollution.
http://192.168.1.99/cgi-bin/scada/ worked.. Seems like older systems need the cgi-bin aswell.
The start-page does not work though.
This LM is running Version: 20150917
I will try to upgrade.
Paul
You better just reflash it, Looks like some files got corrupted or just sing of dying card.
http://openrb.com/reflash-logicmachine3-...-software/
(11.01.2019, 11:35)Daniel. Wrote: Hi
You are probably right.
After updating the FirmWare.. Start-page works, and Visu.
But now the flashsys page is suddently unresponsive..
So I can't check if I have a SD-card issue, or "just" corrupted files.
I probably just have to reflash.
I'll keep you updated on the progress.
After FW update you need to clear cache, seen this a lot..
