Threads: 161
14.01.2019, 14:10
(This post was last modified: 14.01.2019, 14:14 by buuuudzik.)
I've tried today update Processes app on LM5 and after update there is some error:
"Loading failed for „script” element from source „http://ip_address/apps/data/processes/bower_components/webcomponentsjs/webcomponents-loader.js”."
On Firefox it stops whole app but on Chrome app still works but it also logs this error in console.
Done is better than perfect
@buuuudzik, which firmware version are you running, have you tried clearing cache?
@baggins, you need to upgrade firmware for app to work
Threads: 161
15.01.2019, 07:33
(This post was last modified: 15.01.2019, 07:35 by buuuudzik.)
I have the latest firmware. Yes, I've tried clearing cache.
Threads: 31
It was a bug. It is fixed now. Please update the app.
Threads: 31
Hm. It should pop up regardless of the firmware. This should be the older one
https://we.tl/b-Xvs8UZb7a4 install via file. Yo may need to uninstall current first.
Threads: 31
This temperature info is pointless in this app...
Threads: 31
This information is useless and you just wasting resources of LM.
There are different types of hardware and there were 2 different functions to read temp. Not sure which one was used in which version as we didn't develop this app.
Threads: 31
As I mentioned this app wasn't developed by us. It was done by SE and a manager had this genius idea to add this functionality. The whole point for process app is to see live processes so you can debug it when needed. When you monitor temperature then there is constant daemon running in the background which add some resources.
This feature seems to be working on latest fw and latest app.
