Send LM object value to the KNX bus every hour
Hi.
I have 18 temperature object values in LM that i want to send to the KNX bus every hour (to update touchpanels). What's the best way to do this ? Do i have to set up a resident script with 60 min sleep? In that case, does anyone know how this code should be written?
Kai-Roger
You should use a scheduled script for such large intervals. You can tag all objects that needs re-send action and use this script:
objects = grp.tag('resend')
  grp.write(object.address, object.value)
  sleep(0.1)
(30.01.2019, 12:00)admin Wrote: You should use a scheduled script for such large intervals. You can tag all objects that needs re-send action and use this script:
 sleep(0.1)
Thanks (:
