Add external link to built in menu
I tried to add a link to the built in navigation with this javascript:
$(function(){
$('ul.nav-main').append('<li class="level-1" id="show-schedulers"><span class="a"><i class="icon">⇒</i> Schedulers</span></li>');
$('#show-schedulers').on('vclick', function(e) {
  e.preventDefault();
  window.location = '/scada-vis/schedulers';
It is working, but the page doesn't open in a new window If I click the arrow next to the link.
So I tried to find out how the menu is generatet.
In the core.js i found a function called "renderMenuItem", so I tried it with this code:
$(function(){
 var t = {
   islevel: 0,
   hasitems: false,
 renderMenuItem(null, t);
But I don't know how to add an external link.
So the question is: How can I add an external link to the built in menu?
Best regards
forsterm
You need to check the click target element.
$(function(){
   var url = '/scada-vis/schedulers';
   e.preventDefault();
   if ($(e.target).hasClass('icon')) {
     window.open(url);
   else {
     window.location = url;
