Trying to integrate a Trox X Aircontrol with a LM5 and KNX. Our goal is to use the values on KNX and send them to the Trox unit, from KNX to Modbus TCP/IP. We are going to do it in 10 zones, but starting with zone 1. The three values are actual temperatur, actual setpoint and actual ppm value.
I think we tried all sorts of datatypes, all sorts of types and addresses and writable false or true.
Any ideas how it should be?
"manufacturer": "Trox",
"description": "Test",
"mapping": [
{ "name": "Ertemp Zone 1", "bus_datatype": "float", "type": "register", "address": 1009, "datatype": "float32", "value_multiplier":0.1, "writable": false },
{ "name": "CO2", "bus_datatype": "float", "type": "register", "address": 1012, "datatype": "float32", "writable": false },
{ "name": "Setpoint", "bus_datatype": "float", "type": "register", "address": 1014, "datatype": "float64", "value_multiplier":0.1, "writable": false }
}Any ideas how it should be?
