LM5 RS485 check
I have an LM5 communicating with an arduino board via RS485 serial port.
It was working for several months but suddenly it stooped without any obvious reason.
Is there any easy way to check if there is a hardware problem with the RS485 port?
Thank you in advance
George
You can connect two RS485 ports on LM5 together and write a script to test communication between them.
(03.03.2019, 16:24)admin Wrote: You can connect two RS485 ports on LM5 together and write a script to test communication between them.
Didn't though about it... thank's!
