Threads: 161
Which control should I use in Mosaic when I want have on button current state and when I want that clicking will alsways send 1 (fixed value). This function was on visu but I don't see it in Mosaic 3.
It is helpful for gates command open/stop/close and button show current gate state.
Done is better than perfect
Threads: 35
I didn't even knew that stats object work when fixed value is selected
At the moment I don't see direct option only small work around. Create a status object and then create send fixed value object and overlap the status one. You can change transparency to 100% so it won't be visible.
Point to remember for the future.
BE
Threads: 161
For me fixed value should be attached to every primitive control e.g. control for switching object which has title for on and off. I want use it also as fixed value buttons like OPEN, CLOSE.
