See kwh each month
Hi.
I have an object that counts continous kWh for a hot water tank, but it don't tell me the consumption in what month or year.
What is the best way to capture the consumption like 24:00 a clock the last day each month?
Is there altso a good way to show this graphically like in the attached picture? In this picture it shows the last 2 years.
Kai-Roger
Use trends. Yearly view is a bar chart as you need.
(28.03.2019, 16:56)admin Wrote: Use trends. Yearly view is a bar chart as you need.
Something like this? Counter. What about aggregate function?
This is correct but it is safer to use counter with negative data in case your value might go down in some point in the feature. With solar panels it is possible. Use average.
(28.03.2019, 17:16)Daniel. Wrote: This is correct but it is safer to use counter with negative data in case your value might go down in some point in the feature. With solar panels it is possible. Use average.
Smart with negative data!
But will this setup show the exact kwh consumption each month in this view?
Yes this is what it was designed for Smile
(28.03.2019, 17:26)Daniel. Wrote: Yes this is what it was designed for Smile
Thanks  Smile
