MQTT publish json
I am using admin`s mqtt script from this post: https://forum.logicmachine.net/showthread.php?tid=1759
Is there a way to change this:
  object_to_mqtt = {
    ['1/1/1'] = 'out/topic1',
    ['1/1/2'] = 'out/topic2',
to send a variable that is a json string with multiple values (something like this):
valueX= grp.getvalue('32/3/1')
valueY= grp.getvalue('32/3/2')
topic1 = '{"site": "building", "equipment":"ventilation3601", "current_mode":"'..valueX..'", "current_status":"'..valueY..'"}'
  object_to_mqtt = {
    [topic1] = 'out/topic1',
-John
Do you only need to publish states or do you need two-way communication?
(08.04.2019, 09:50)admin Wrote: Do you only need to publish states or do you need two-way communication?
It would be nice to have publish and subscribe in the same scipt, but I already have another working script for subscription so not a must.
John
You can use event script to publish and disconnect after publish, like in this post: https://forum.logicmachine.net/showthread.php?tid=1793
Use json.encode to create your data string instead of creating JSON string manually.
This code will publish once connected and disconnect once publish is done.
client.ON_CONNECT = function(stat, code, err)
  if stat then
    client:publish('devices/' .. device_id .. '/messages/events/', data)
    log('mqtt connect error', err, code)
client.ON_PUBLISH = function()
  client:disconnect()
  running = false
(09.04.2019, 07:16)admin Wrote: You can use event script to publish and disconnect after publish, like in this post: https://forum.logicmachine.net/showthread.php?tid=1793
 if stat then
 client:disconnect()
 running = false
Thanks! I will give it a try.
