Port name issue
I have a USB to M-Bus adapter(Prolific) connected to my LM5, via a powered USB-hub.
From time to time my LM stop receiving telegrams from the M-Bus adapter.
When I check the serial port name, in the system status window, the port name might have changed from  "/dev/ttyUSB0" to "/dev/ttyUSB1", and my script handling the data needs to be changed accordingly to work again....
Is it possible to connect to LM via telnet/ssh and give my device a static name with udev rules?
If you only have a single USB converter you can use a function to find port name:
1234567891011121314
function findttyusb()   for _, dev in ipairs(io.ls('/dev')) do     if dev:find('ttyUSB') then       return '/dev/' .. dev     end   end end tty = findttyusb() if tty then   require('serial')   port = serial.open(tty) end
