Adding Group Address on Canx App
I started on my first real Canx project today, and i have some mixed feeling’s regarding adding Group address in Canx App on LM.
1.     Is there an easier way to add several group addresses in Canx App, then adding one by one?
(I know that i can import from a Json file.)
2.     I wanted to import a json from ets, in this case I only used ets to make the GA faster. So, I didn’t add any devices, because this project is only CanX. Used the converter on Openrb.  Then I got the error (Error: missing manufacturer xmls) after adding a device the error disappears.
3.     Since I did not have any objects linked in my GA, they did not have any datatype. When trying to add the json file in to the CanX app all my GA was rejected. There was no button to press for adding GA without datatype, like on LM.
4.     When adding the correct datatype manually to my GA in ets. Almost all my GA was imported. The one that was not imported was 3.007 Dimming Control (4Bit used for dimming)
So, my question is, am I doing something wrong? Or is this the best way to make a lot of GA fast on CANx app?
BR Even Sundgot.
When I first time tried the app I had the same feelings but it was due to my old ETS habits. When working just in CANx it is much faster just to create new objects while configuring the device. You just press add new and if the naming is OK you just save, otherwise rename it to what you want. I'm always first configuring all the actuators, creating all the objects and then just link all the sensors. For me this is much faster than ETS.
The ETS approach make sense only if you actually going to make link between KNX and then you will add objects to each group so the problems you described will not happen.
Feel free to drop any feedback. Negative is even better as then we can improve Smile
(31.05.2019, 08:41)Daniel. Wrote: Hi
Hi Daniel,
I understand what you mean, and I can agree in some points. But on large buildings or even projects with a lot of light zones i prefer to do it a little different than you.
My process is that I start with making all known GA. In a structure that I use on all my projects. Example:
2 Main: Lights On\Off
1 Middle: 1. Floor.
105 GA: 105 Office [Ceiling Lights] (Pos7.)
This equal:
 2/1/105. Lights On\Off - 1. Floor. - 105 Office [Ceiling Lights] (Pos7.)
Normally I make all of these on just one of the functions at lights. Then copy them to the rest. Its not the fastest way, but then I know that I have full control.  When importing it to LM its very logical and easy to filter.
Some functions that I miss in the canX app.
1.     A way to add several GA. And maybe in a structure like ets? Main – Middle – GA
2.     The possibility to import GA from excel.
3.     The possibility to import GA without datatype from Json.
4.     When adding an object to an GA without datatype, the datatype is automatic set.
Maybe this is just me being picky about my GA structure. Rolleyes
BR Even Sundgot.
