Mosaic custom values
In objects i added custom values to show the hvac status. 1-Comfort, 2-pre comfort, 3-economy etc. Works fine in objects log.
But when i add the group adress to mosaic it shows 1,2,3,4.
Is there a possibility to change this.
Object Custom values are not linked with Mosaic.
In widget editor there is special object where you can define the same. Mosaic 3.0
This is created in the widget creator and is mosaic 3.0. But not sure were you can add custom values.
Added the json .
.json   widget.json (Size: 2.33 KB / Downloads: 14)
Use element 'Text for value of address'
Once Selected there is definition how to add
1| Name 1
2| Name 2
etc.
