Alarm System
Hello everyone,
I do not know so much from the FB.
I have a homelynk .... and wanted to ask if it is possible to program an alarm system in FB.
I have magnetic sensors on the doors and windows.
But I only want an alarm when I'm home and someone opens or closes the windows. So no message on my phone or something.
The magnetic sensors are connected to a Schneider 44592 binary input REG-K / 8x10.
Can you help me there?
Greetings David
What tells to HL that you are at home?
(16.07.2019, 18:10)Daniel. Wrote: Hi
sry but HL?
I mean when I sleep at night, I want to get the message ... maybe that's the light on or something
HL = homelynk
(16.07.2019, 18:42)Daniel. Wrote: HL = homelynk
oh sorry ... Confused
I would flick on a KNX switch or the Schneider multi touch on / off
Import this library to HL in user libraries
In FB you will have new block Alert
Fallow the instructions in descriptions.
Here is FB backup to show you how to set it up.
PS. Much simpler to do it in script Smile
.gz   Libraries-Alarm-LogicMachine-2019.07.17-12.28.tar.gz (Size: 1.59 KB / Downloads: 21)
.json   alarm.json (Size: 5.19 KB / Downloads: 20)
(17.07.2019, 11:32)Daniel. Wrote: Hi
Thanks, i try it but it doesn't work  Confused
What do i wrong?
.json   alarm1.json (Size: 5.2 KB / Downloads: 11)
I got it.
but if I turn Enable on ...
and then close a window (sensor off) I have no alarm trigger
It is or gate, do you want it to trigger alarm for on and off? This doesn't make sense to me.
Here is library with Alarm2 which will send true on any telegram on the input if enable is true.
.gz   Libraries Alarm 2-LogicMachine-2019.07.18-10.25.tar.gz (Size: 1.65 KB / Downloads: 12)
yes i want it to trigger alarm for on and off...
because if I sleep at night, and the window is tilted.
if then someone closes the window to open it completely, the alarm should also trigger
the new library works fine....big THANKS!!!!
hey last question, what do I have to do that the message on the output is only 2 min on and then back off again?
Add this DelayOff block. Instructions in description.
The ready made blocks are bit useless I see Wink
.gz   Libraries-Alarm 3 LogicMachine-2019.07.19-14.02.tar.gz (Size: 1.93 KB / Downloads: 21)
(19.07.2019, 13:04)Daniel. Wrote: Add this DelayOff block. Instructions in description.
Thank you Big Grin Cool
