Central statuses
How prepare calculating of central statuses on Logic Machine by event-script and tags? E.g. "1Floor status", "Kitchen status" ...
Here are 2 functions for getting OR / AND values for binary objects with the same tag. You can then use the result to write out the status.
function tag_and(tag)
  local objects, result
  result = true
  objects = grp.tag(tag)
    result = result and object.data
  return result
function tag_or(tag)
  result = false
    result = result or object.data
  return result
(16.02.2016, 11:22)admin Wrote: Here are 2 functions for getting OR / AND values for binary objects with the same tag. You can then use the result to write out the status.
 result = true
 return result
 result = false
 return result
ThanksWink
Is there any solution to prevent executing this function on every tag change?
When there is 5 - 10 statuses, there is no problem, but if there is 100 or 200 statuses of whole house, script has to execute 100 time which can slow down LM...
(18.02.2016, 08:21)Pawel Wrote: Is there any solution to prevent executing this function on every tag change?
Before doing a function you can check if the status of this lamp is the same that the central status.
tag="kitchen"
if status1~=central then
tag_or(tag)
