Threads: 20
I am testing Amazon Alexa but I when try to sync, I get this error: "Sync cloud Last: Error"
I also get the following error log: "Line 751: MQTT.client:publish(): Not connected"
Thanks...
Threads: 31
It means your LM can't connect to our cloud. Check if you configured the network interface correctly. It does happen sometimes that router block outgoing port 1883. Does Mosaic work?
Threads: 31
For sync port 443 is used but 443 wouldn't be blocked as then browsers wouldn't work. When you say mosaic can sync, Can you actually control objects from cloud in LM?
Threads: 31
Which FW do you use?
Try reboot.
Threads: 31
Can you uninstall Mosaic 305 and use the Mosaic 3.0, the one from 20190527. This 305 was just uploaded and could have some issue which I'm just checking.
Threads: 31
Can we get access to your device? If yes send me to PM please.
