DALI v.2 protocol
customer asked questions regarding LM DALI interface. I need fresh info. Does DALI interface support DALI v.2 protocol - multimaster device support and DALI sensors connection? If not - is planned to upgrade interface? I have genohm-scada-dali 20190123 library installed. Is it latest library?? If not, where possible download latest library?
Alex
Internal gateways work in single master mode right now. DALIv2 can be supported but it will require a protocol change. CANx-DALI gateways have partial support for DALIv2 - you can receive data from other masters but it must be parsed manually via a script. Addressing for DALIv2 is not yet implemented. Right now we are focused on making a more or less complete solution for CANx-DALI then implement the same support for internal gateways.
admin,
big thank for updates, will inform my customer, if possible will try to use standard RS485/DALI modules.
Alex
